跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Back Camera and LED/Flash not working
When I open the camera app, front camera works fine but when I switch to the back camera the display goes black. In the top left corner it shows the following message, "Flash is Disabled - The iPhone needs to cool down before you can use the flash." But the phones temperature feels normal.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
Have you tried to replace the camera?
iPhone 5s 后置摄像头更换
If yes, try these steps:
1. Go to Options
2. General
3. Restore and select reset settings
这个答案有帮助吗?
得分 0
添加一条评论
I have this same problem I tried to replace the back camera but it didn't solve the problem
这个答案有帮助吗?
得分 0
添加一条评论
You need to replace the flash module, the clue is in the error message lol. The flash module is part of the power button cable.
这个答案有帮助吗?
得分 0
1条评论:
Hello again I haven't solved the problem yet. I don't know if this is related with the problem or not, but a few days ago I went snowboarding and I left the iPhone on the front pocket of my backpack, it got really cold and I noticed that the flash started to work again, not the camera. Once it got warm stopped. Any clues at all?
完成的
添加一条评论
If flash work when it is cold then most likley your cam is defect and you have to place a new back-camera.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Menhal Rezk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 3,904
