跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
iPhone keeps powering off for no reason
My iPhone I've had for a very long time , it is cracked a lot but still works . BUT overtime i power it on it has to stay on the charger , if i take it off the charger for one second it powers off AT 100% and takes hours to power back on , how do i fix my phone so that it can stay off the charger and function perfectly fine ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Is this really an iPhone 4? Dude, sounds like that battery is iToast. You could replace the battery, but if the phone's as cracked up as you say, perhaps it's time to retire it.
[edit] And by that I don't mean to contradict the iFixit credo, but that the expense of a iPhone 4 battery replacement kit may not be justified by usefulness of the resulting repaired iPhone.
iPhone 4 Battery图片
产品
iPhone 4 Battery
$11.99
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Guaranteed the battery. You just nailed every symptom of a bad battery. Replace it and you should. be back in business!
这个答案有帮助吗?
得分 2
1条评论:
Except for the battery expanding / puffed bit :P.
完成的
添加一条评论
添加你的答案
Mailea 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 58
