battery compartment won't close & won't click when battery is put in
I'm not sure what the problem is but I put battery in pushing in orange battery latch and it does not latch
The battery pack should click into place without requiring excessive force. If it does not, be careful not to force anything as this will make things worse!
Check the following:
这个答案有帮助吗?
byte me (12 characters plus)
There is a sequence THAT MUST BE FOLLOWED TO CLOSE THE BACK COVER SECURELY. STUDY THE BATTERY FACING SIDE OF THE BACK COVER CAREFULLY - PONDER FOR A MINUTE AND THE PROPER SEQUENCE WILL BE REVEALED. iTS CLOSE THE SIDES FIRST AND THEN THE TOP AND BOTTOM NEXT.
Yes, the battery can be replaced but it is difficult to replace the battery cover. Actually, it's pretty easy. Just place the KM on a hard flat surface and place a small book on top of the battery cover and apply some pressure to it. The 'click' will immediately be heard.
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 32
总计 10,737
