跳转到主内容
Launched in 2012, the Asus X54C features an Intel Pentium Intel® Core™ i3 Processor, Intel® Pentium® Dual-Core Processor and Intel® Celeron® Dual-Core Processor
19 个问题 查看全部
both hard drive and fan areas are vibrating on the laptop
my x54c laptop hard drive and fan areas are vibrating when under normal web browsing use, however when im playing a game like eve online the issue goes away while the game runs but after i log out of the game they come back after a few minutes, i would take the laptop fully apart but im not experienced enough to do that without harming the laptop and i cant afford to take it into a shop and the warranty has long since expired. i cant afford to lose this laptop at this point in time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I suspect your fan is out of balance so when its rotating at a lower RPM you notice it.
I would start off by popping off the bottom cover to clean out the dust and other junk.
Get a small soft paintbrush and a can of can'ed air. Carefully scrub down the parts to loosen the dust then use short burst of air to push it away. Don't over spin the fan and don't forget to clean out the heat sink fins.
See where things are after that. You may need a new fan unit if it still a problem.
这个答案有帮助吗?
得分 2
1条评论:
thanks will do that when i can.
完成的
添加一条评论
添加你的答案
Jeffrey Millican 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 224
