跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
horizontal and verical white lines on screen
I did housing my iphone6 for several times. Yesturday, I saw one horizontal line after closing my phone, touch not working just on the line. Opened and reconnect to fix this, but it got worse. After reconnecting several times, touch is not working anywhere. I see no ripping on the cable. Line moves when I open and close the lcd. Is the sensor gone? or can I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Make sure you have the digitizer cable firmly seated and that it is clear of any dust. I would also try using an alcohol wipe to clean the contacts. Since their is a visual problem there is something wrong with LCD, not the touch screen, but since you said they both are having issues you may have an issue with your logic board.
这个答案有帮助吗?
得分 1
1条评论:
I went to the iphone shop and they tried new lcd and it worked. so i guess the logic board is fine. i tried wiping with water. I guess i try alcohol.
完成的
添加一条评论
添加你的答案
JoonYoung Ko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,369
