跳转到主内容
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
104 个问题 查看全部
Where do you add fluid for the front axle after removing it
Right passenger front axle was removed on a 2001 Ford Escape 3.0L V6 4WD to gain access to the alternator. We assume the axle fluid coming out is ATF fluid on the front. Someone said pour some back in there until it runs out. But wouldn't there be a place to fill it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Be careful how much trans fluid goes back in the SUV needs to be running and warmed up when checking the transmission fluid level. consult the owners manual if you just add it you may be adding to much and thats just as bad as having to little
这个答案有帮助吗?
得分 2
1条评论:
working on my nissan cv axle came off splilling some fluid and i wasent sure wich kind of fluid it was thanks for helping us
完成的
添加一条评论
Hey edwardsdefender51 ,
The front CV axles insert directly into the transmission, Just top off your transmission fluid.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
edwardsdefender51 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 1,470
