Is my Htc One M8 beyond repair?
My HTC One M8 just doesnt switch back on after I tried to restart it. Earlier, it was showing no network for some reason so I thought re-starting would hopefully fix the problem. But it never switched back on no matter what. Is it hard bricked? All it shows is the orange blinking LED while charging but there no light on the screen. Also, I was using a charger from a different phone. What can I do to fix this? Or is it beyond repair?
Hold the power and volume down button for 15 seconds and try turning it on again.
由 Ben 完成的
I've tried all possible button combinations but nothing seems to work.
由 Ahmed Chogle 完成的
I think you might need to open up phone and replug battery cable.
HTC One M8 Headphone Jack/Micro USB Board Replacement
Follow this guide up to step 10 and do reverse.
由 Ben 完成的
If the orange light is blinking, it generally means the battery is too low to turn on. Once you get a solid orange light you should be ok. Have you tried a different charger?
由 Rik 完成的
