跳转到主内容
Can I swap the monitor between 2012 and 2011 model?
Hello I have a MacBook Pro (13-inch, Early 2011) with broken screen, everything else is working. My friend has a MacBook Pro (13-inch, Mid 2012) without logic board and hard disk, he can give me the screen. The question is: Can i put a macbook pro 2012 screen in 2011 macbook pro?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hey marcinjak9 ,
I can't find anything explicitly stating that they're compatible, but according to this Answers thread: "I'm trying to find the difference between 661-5868 and a 661-6594", someone was able to swap an early 2011 display on to a mid 2012 MBP. I imagine that it should work the other way as well, but don't quote me on that. The actual procedure of replacing the display is the same across both models, so it definitely can't hurt to try it!
MacBook Pro 13" Unibody Early 2011 显示屏图片
指南
MacBook Pro 13“Unibody 2011早期显示屏更换
难度:
困难
1 hour
MacBook Pro 13" Unibody Mid 2012 显示屏更换图片
指南
MacBook Pro 13“Unibody 2012中期显示屏更换
难度:
中等
30 minutes - 1 hour
这个答案有帮助吗?
得分 2
1条评论:
Yes i've noticed the same procedure of relpacing but i wanted a confirmation.
And swap logic board from 2011 to 2012? it's possible?
完成的
添加一条评论
添加你的答案
marcinjak9 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 186
