跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
No USB Connection after I broke little SMD element near connector #4!
I can neither charge the iPhone nor connect it to iTunes. Nothing happens when the phone is connected to a USB/charging cable. If the iPhone is off, connecting a cable turn it on.
It seems I broke a little SMD element near connector4 of the logic board when I disconnected this connector with a screwdriver!!!
Does anybody know what type of SMD element that is and where I can buy it? It is so little that I lost it on my table and never find that part again!
See picture:
Update
I am having this problem, but I just checked my board and that SMD looks perfectly intact. What else could be? The connector 4 is firmly attached as well...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
If you still have the mentioned SMD coil and your iPhone starts up when connected with usb charger it's another problem. Start you own question!
The coil filters the USB data lines. Maybe your line is broken on another point?
完成的
添加一条评论
1个答案
已选择的解决方案
I found an answer myself:
This element is coil!
Connect like this:
http://forum.gsmhosting.com/vbb/f631/iph...
这个答案有帮助吗?
得分 2
1条评论:
It was the "NOISE FILTER COM MODE 90 OHM SMD" -> Digikey part number: P14216CT-ND. http://forum.gsmhosting.com/vbb/f631/iph... - Data Sheet here: http://industrial.panasonic.com/www-data... (Common mode Noise Filters, Noise reduction of high-speed data lines such as USB,
LVDS, and HDMI lines)
完成的
添加一条评论
添加你的答案
James Bond 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 13,032
