跳转到主内容
The ZenFone 5 is a 6.2" smartphone made by Asus, released in May 2018. The phone has two rear-facing cameras and comes in Meteor Silver and Midnight Blue.
19 个问题 查看全部
After replace display, Asus zenfone 5 stays on only with power cable
Hello everyone! Sorry for my english :)
I have a asus zenfone 5 who fell and as a result has cracked the glass. I bought a kit for the replacement of the display and yesterday I replaced it.
The display works perfectly but there is a problem: the phone turns on only when I plug in the power cable and goes out as soon as I remove the cable. Once you turned on the phone the power and volume buttons works and the battery is detected and appears to be in charge, but without the power cable the phone is not working. I also tried to disconnect the connector that connects the battery to the phone and the phone still comes on connecting the power cable, however, does not detect the battery.
What can it be? Should I try to replace the battery? Or is it more likely that damage has a connector (does not seem to have broken anything).
It 's really weird because when the phone is connected it works and it is in charge.
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
check the battery flex cable or measure the battery voltage with a multimeter
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Miriam baraldi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 459
