跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1234 个问题 查看全部
Horizontal Black Lines On Screen
I recently bought an iPhone 5c off of a friend. Seemed to work perfectly except for the top right corner was a little out of place. Suddenly I was getting dim flickering lines across the screen. It also seems that the screen is a lot less bright. I figured out that if I apply pressure to the top right hand corner of my phone, the lines would go away, but would come back once released (I tried placing tape there but it didn't help). Does anyone know of an easy fix for this issue? I tried ordering a case to see if it could permanently push in the screen, but I figured I would rather just have it fixed forever if I decided to take off the case. I really don't want to go to get my screen replaced for such a simple (or I presume) problem. I kind of figured it might have to do something with the wires connected to the LCD but I do not want to just open my phone without knowing what to do. Thanks!
~Henry
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Don't apply pressure to the screen because it might crack the display or LCD. It sounds like something may be stopping it from laying correctly in the phone. Try removing the display and make sure all the connectors are properly seated and that there isn't anything stopping the screen from laying down.
这个答案有帮助吗?
得分 1
1条评论:
Ok thank you I'll try that!
完成的
添加一条评论
添加你的答案
Henry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 271
