跳转到主内容
How confirm which side's problem when keyboard not working?
Hello.
I have a Toshiba A200 laptop and it has problem that some keys not working.
Not working keys are F7, 7, U, J, M. It's in a column. So I can assume matrix is broken.
What I wonder is, how to confirm it's a problem of which side. Keyboard part? or mobo part?
Because it looks like keyboard part's problem, but I guess when pin of connector or line in mobo is broken should have same symptom.
I have a multimeter, so I can check disconnection some line or pin if I know which part I should.
Please help me how to check.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
It would be more logical to think that the problem is within the keyboard rather than on the motherboard, as there is pressure being placed on the keyboard by typing, rather than the motherboard.
Here is a link which shows the replacement of the keyboard in your laptop. As you can see the keyboard is very thin and more liable to problems of breakage than a motherboard.
The preferred option with laptop keyboards is to replace them as you are likely to create more problems than you will solve in trying to fix it.
https://www.youtube.com/watch?v=cEb8fB3J...
In the meantime, if it is convenient, plug in and use a USB keyboard.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Anonymous 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 905
