跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Digitizer problem even after replacement
I have 2 iPhones 5C.
One is locked to a network and the other is unlocked.
The unlocked one doesn't have any cracks on the screen and the display properly shows everything, but it doesn't recognise touch.
So I've swaped the entire screens, from the fully working phone I took off the screen and the digitizer and places it on the faulty one. ( I assumed it probably was a cable problem or a faulty screen with digitizer) but even after the swap, the faulty phone doesn't recognise touch......
Could this be a motherboard error?
if so, is there anything that can be done to remove the problem?
i would appreciate some advice if anyone had a similar problem b4.
Thank you.
Update (05/13/2016)
there doesn't seem t be any damage on the connector docs
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Unplug the battery from the phone with the touch screen issue. Keep a screen plugged in and hold power button for 5 seconds. After you've done that, plug in the battery and turn on the phone again. See if that helps.
Does it not recognize touch at all? That means maybe water damage or damaged component chip near the digitizer connector on the logic board.
完成的
thank you for the advice, tried it..... it didn't work tho, it seems that it's a motherboard issue, but I'm wondering what could have possibly went wrong on the motherboard when I know there has been no water damage 100% , any advice as to what could I do next?
完成的
添加一条评论
1个答案
Try Ben's power recommendation first. It's also possible you have a faulty screen but the digitizer connector on the logic board is very delicate, can you see if there is any damage on the connector? If there, you may need to have it microsoldered :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tamara Vranjes 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 139
