跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
iPhone won't open with isclack or suction cup
My phone will not open at all with both the isclack or a suction cup.
As a side note, the screen was replaced a while ago by apple.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Make sure you take the two bottom pentalobe screws before doing it.
You also need to be careful of the home button ribbon cable that is plugged into the charging port dock assembly.
So when you do lift up the screen, make sure you only lift it slightly so you don't rip the cable.
Also you don't have to use suction cup or iSlack. There are other ways such as using a razor blade. You need to lift up the bottom part first with the razor blade to pop it out a bit then pop it up a bit on the sides of the screen. The razor blade only has to go in enough to make it possible to pry up the screen a bit.
Note that you put the blade between the metal frame and the front display frameborder. NOT between the glass and the front display plastic frame.
完成的
添加一条评论
1个答案
已选择的解决方案
This is just how I open many iPhone 5, 5s and 6 screens. Your mileage may vary.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Tony Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 926
