跳转到主内容
The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
Will not connect to internet
I can't get my printer to connect to the internet. Says that my password is invalid. HP says the problem is with Time Warner. Time Warner says it the printer. Other devices (iPad) working fine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Hi,
I assuming that you cannot connect to your wireless router with the printer.
Just double checking, have you proved that you are trying to connect to the correct wireless network? Switch off your router and verify that the wireless 'network' that you wish to connect to is no longer visible from your printer.
What make and model is your router?
完成的
Try a factory reset on the printer first, if that doesn't work try resetting the router.
完成的
添加一条评论
1个答案
已选择的解决方案
On a couple wireless printers, I've had to actually connect the printer to the system and install the software -- selecting wifi from the menu. Once set up, I could move it to another location.
If I recall the software downloaded updates along with and installing a firmware upgrade for the printer. I would give this a shot.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Rene Mose 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 2,536
