跳转到主内容
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
Why won't my iPod touch turn on?
I received an iPod Touch 5th Generation from a friend of mine. I went to turn it on and got nothing. I then charged it for about an hour and got nothing. I tried plugging it into my laptop and it didn't read it either. What is wrong and how can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论:
Check the charging port for any dust or lint inside. Clean it with a toothpick or equivalent to get out the gunk. Hopefully that gets it charging.
完成的
It looks completely fine and the device heats up when charging, but the screen doesn't turn on and it is not read by my laptop
完成的
The screen may have come disconnected inside take it in for repair or if you know how open it and make sure cable is set properly
完成的
I think it has a bad LCD. I will bring it to get fixed today and see what an expert has to say. They did an excellent job fixing my iPad so they can probaby fix it
完成的
In a couple of days my iPod wouldn't turn on and can't click the home button to reboot it. My iPod wouldn't turn on and can't reboot it with the home button bc my home button doesn't work. It was back on when i had a dead battery to connect my charger.
完成的
添加一条评论
1个答案
Make sure button on top is set so that you do not see the orange lock color beneath then push and hold LG. Round button for up to 10 seconds it should come on if battery is charged if not I suggest taking it in for repair
这个答案有帮助吗?
得分 0
3条评论:
What do you mean by orange lock color
完成的
Under the switch on top one side has color (the lock) the other direction no color ( un-locked )
完成的
I don't have it with me so idk what you're talking about
完成的
添加一条评论
添加你的答案
Jacob Gonzalez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 270
