跳转到主内容
The hard drive disappears from desktop and won't boot?
I am working on a iBook G4 800mhz and I'm having a bit of trouble. The hard drive disappears from desktop and won't boot. It will come up occasionally and works fine then wont work. I tried to install the OS again but it disappeared during the install. I am able to boot from the install disc but now the drive doesn't show up. The drive is only a few months old and I am beginning to think that its a firmware issue or just a bad drive.
I am at a loss as to what it can be. A bad drive, controller issue, motherboard????
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Find your receipt and return the drive.
这个答案有帮助吗?
得分 3
2条评论:
完成的
完成的
添加一条评论
Check the Connector
to Logic board for lose bent pins.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Michael Perrick 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 7
总计 1,208
