跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
No service on phone but ICCID shows in About
I've got an iPhone 6 where it constantly looks for service.
I've tried 3 different sims.
The SIM card shows in the ICCID field under Settings > About.
I've swapped the logic board into a new phone case\shell where that housing\cellular previously worked, however, I still get no service.
Is cellular service linked the the logic board somehow?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
8条评论
Is your phone locked to a specific carrier?
完成的
I don't believe so, is there a way I can check? Searching via google only brings up those scams to pay for unlocking service.
完成的
Well I use sim-unlock.net to check these stuff. Costs like $5 to check via imei number so I don't recommend doing though.
完成的
Is there really no other way?
Boggles my mind to be honest. The old school symbian OS nokia phones were a dream to work with compared to these. :\
完成的
You have checked that the date and time is correct on the phone right?
完成的
显示更多的3条评论
添加一条评论
3个答案
已选择的解决方案
Of course the cellular service is linked to the logic board, why else would you put a logic board in a phone?
It is likely to be dead power supply to the transceiver chip, or dead transceiver chip.
这个答案有帮助吗?
得分 5
6条评论:
I've noticed that the cellular antenna is in the charger port piece.
This makes me curious if it's something else, somewhere else.
完成的
Are you able to go into a little more detail re~ transceiver chip?
完成的
There are 2 cellular antennas, it is not possible for them to fail at the same time.
So it must be a chip problem.
完成的
Hey Tom Chai, are you able to locate these for me? on a schematic or diagram?
完成的
Basically every chip on the lower half of the board, it's way too complex for ppl without the experience or tools.
完成的
显示更多的1条评论
添加一条评论
Check IMEI via *#06# and if no IMEI is displayed then you have a issue relating to baseband chip.
这个答案有帮助吗?
得分 4
添加一条评论
In "about" do you have an IMEI number?
这个答案有帮助吗?
得分 2
11条评论:
Yes I do have an IMEI in Settings > About.
It does does all detect the sim as it shows the ICCID
完成的
I've come across the same issue, this is usually due to the housing you've used. I found personally that using an aftermarket Housing is the wrong move, use only an original / OEM Apple housing if you can and you shouldn't have the issue.
完成的
I've used a legit apple housing?
I'll try testing with a different iPhone 6 housing (OEM apple) and test to see what happens.
完成的
From what I've been told / seen, and what the research suggests, there are no Original New Housings available for purchase / use, only second hand and maybe A-Grade aftermarket? That's just what I've found in my experience
完成的
Ahhh Sorry, I meant I've used housings from broken screen phones where the logic board has been removed but everything is in tact (sometimes screens are missing too)
完成的
显示更多的6条评论
添加一条评论
添加你的答案
Nigel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 3,747
