跳转到主内容
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
Why is my tablet keep turning on and off
It turns on and then off and I can't do nothing with it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
what was done to start the problem ? was it dropped or were you rooting it?
完成的
添加一条评论
1个答案
已选择的解决方案
If the machine was not damaged either by a drop or you trying to root it you can try disconnecting the battery to clear the cache so it gets a clean boot. Here are instructions to disconnecting the battery
如何替换三星 Galaxy Note 8.0 的电池
if you just disconnect it for 60 sec it will clear the memory and allow a clean boot .Hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Meghan sharp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 264
