跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
Unfortunately, Messages has stopped. Samsung S6 Edge Error
I've had my phone for about a week and now i'm getting this error when I try opening or sending texts. I have tried deleting cache and data, even factory restarted the phone but nothing worked. How can I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You probably either have to reload the system firmware via Odin with Downloaded firmware from sammobile or do a system restore via Samsung kies. Note that doing it by kies will also do a factory reset on the phone.
Are you using Google hangouts or the normal messaging / text app?
这个答案有帮助吗?
得分 1
2条评论:
I'm using the normal text app
完成的
You can use Google Hangouts as an alternative.
完成的
添加一条评论
I have the same problem on my galaxy s6 active, seems like it's been ever since it updated to 6.0.1. On mine anyone in my active conversations list i can text just fine, but it will not send or receive to any new numbers if i try i get the message "unfortunately messages has stopped"
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
danacalderwood 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,314
