跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
问题已关闭
Could be many problems
I replaced the digitizer as had a smashed screen last week but must have been a dodgy digitizer because the cable was far too long so couldn't fully stick it down because it was bulging. Also after this repair the home button want working do had to use the accessibility controls. So yesterday it stopped working completely and I don't think there is much I can do because I can't hold down the sleep wake and home button to do the reset thing
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Part of the cables on these screens need to be adhered back onto the digitizer before plugging in. If they weren't adhered, then they would appear far too long.
Your home button connector on the motherboard may be damaged. Or the cable not plugged all the way in. Or if you purchased a screen with a home button pre-installed, then it may be faulty.
Unfortunately, the only ways to do a reset is to allow the battery to drain to absolute zero (which could take forever), or open it back up to see what's going on. If the home button connector and cable all looks good and you don't have a spare to test with, the other way to do a reset is to disconnect the battery briefly. Be careful though, as the motherboard is held down with adhesive.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 37
