跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
5c Ghost Touch Issue
I have a 5c that has a mind of it's own... sometimes. From the home screen, if I hover over an icon, close but not touching the screen, an app will activate.
This happens sporadically. Sometimes it will be fine and function normally and then, without reason, it will start randomly activating apps, bring up the keyboard and type, without touching the screen.
It appears that when it freaks out only one area of the touch screen is affected. So when I touch the upper left of the screen it seems to activate whatever is in the middle/lower right. And then without warning, everything works fine for awhile till it happens again.
I've tried 2 new screens and have the same issue. It has been fully restored and updated through iTunes and nothing changed.
I assume it is a hardware/logic board issue but not sure where to start looking.
Any ideas?
Thanks!
Brian
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
First I would try cleaning the digitizer socket connector, with 90% isopropyl alcohol. Then, if that doesn't take, it's likely the socket needs to be replaced. Another option is that the touch ic, either needs to be replaced, or the solder needs to be reflowed
http://m.youtube.com/watch?v=tU44AjBpG6k
http://www.googleadservices.com/pagead/a...
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
Brian Clark 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 647
