跳转到主内容
加入维修社区 - 创建账户
The following guides will walk you through common troubleshooting and replacement issues that Pentax users have encountered. Each guide contains complete information that will easily direct you through the process.
Date/time doesn't hold when battery removed
Pretty much as above. I assume there's an internal battery that has failed or I am overlooking something. After resetting, I DO use "settings complete" and "done", but it defaults to manufacture date when battery is removed for recharging. Thanks for any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
According to the User manual for your camera : the date and time may be returned to the default settings if the camera is left without the battery for a long time.
This seems to indicate that there is another battery (usually user inaccessible) which is used to maintain certain settings, predominately the Date and Time.
How long is a long time? It should certainly be longer than the recharge time of the main battery.
I agree with you the settings backup battery has failed.
Update
Here is a link which shows the teardown of a WG3. At 16 seconds into the video I believe that you can see what I think is a button battery on the mainboard, (directly above the red end of the screwdriver handle). If it is a standard button type battery, these are usually not rechargeable but have a long life, especially if their function is usually performed by the main battery. They only have a very low discharge current when the main battery is removed. In some older PC's the CMOS battery was of the same type and usually lasted 6-8 years before replacement was necessary. Mind you it is a lot easier to replace them than to replace the one in the camera by the look of it
https://www.youtube.com/watch?v=l0A6MnF6...
Planned obsolescence - perhaps?
这个答案有帮助吗?
得分 4
2条评论:
Do you know what size the battery is? Is it soldered into place? I don't want to start disassembly until I have the necessary replacement parts.
完成的
@nassarmu
Sorry, I don't know.
完成的
添加一条评论
添加你的答案
Buddy Huggett 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 54
总计 2,412
