跳转到主内容
苹果于2015年10月14日发布的第二代桌面触控板。型号A1535。
12 个问题 查看全部
How to change the glass of magic trackpad2
I accidentally make my magic trackpad 2 glass cracked.
I still can use the magic trackpad 2 without any issue,just the glass cracked
how can I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
2条评论
Hi,
I have the same problem, how did you solve it?
Thanks.
完成的
@palazzolo - I'm sure they replaced the trackpad unit.
完成的
添加一条评论
3个答案
已选择的解决方案
Sadly Apple (or other part houses) don't offer spare parts for the trackpad. You'll need to buy a new one.
这个答案有帮助吗?
得分 6
添加一条评论
I contacted some glassmakers to make a sample and after replacing the glass myself, it worked great! I resurrected my Magic Trackpad!
Review the guide here: [无效指南链接]
这个答案有帮助吗?
得分 1
添加一条评论
Hi
Sadly there aren’t really any repair guides of the Magic Mouse however,this isn’t really recommended be on eBay there will be lots of faulty ones you can use as a donor so if your up for a challenge find a YouTube video or follow a teardown and see how far you get
Like I said previously this isn’t recommended but it’s up to your self if you want a shot and if you need any advice please do not hesitate to ask
这个答案有帮助吗?
得分 1
3条评论:
@hellomacos - There is a guide! And a parts source too! @applerepaired put in the effort for the guide and has the needed replacement glass.
完成的
That’s amazing Dan!
Well done to @applerepaired for finding this information!
完成的
Thanks for the support!
完成的
添加一条评论
添加你的答案
ruslylee79 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 15
总计 5,618
