跳转到主内容
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 个问题 查看全部
Ipad in black screen can only be detected in DFU mode
My Ipad suddenly shut off, no response while pressing home and power buttons, pc cannot detect Ipad, and can only be detected in DFU mode, but while trying to restore it in ios 9.3.1, Itunes displayed "waiting for Ipad" and Ipad disconnects itself from pc while restoring.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
This just happened to me with my iPhone, although I threw it against the wall first. Basically if you are unable to get it out of DFU/Recovery mode using the methods listed when you google "How to get iPad out of Recovery Mode" there is likely a blown fuse on the logic board. Does the iPad get hot when you have it connected? Then this is likely the issue.
It could also be that your battery finally gave out, and it could be time for a new one. Try the methods when you google that above, and see if it works. If not, it may be destined for the shredder, and in that case I hope you had iCloud set to automatically back up everything.
这个答案有帮助吗?
得分 0
3条评论:
Yes Sir Matt Gordon, Ipad gets hot when I connected it to itunes at DFU mode.
完成的
Then likely it is a blown fuse. It would require board level repair, which you can find but it is rather expensive I believe. It is not something you can just swap and go, its something that is running hot and causing the recovery mode to kick in. Sorry :(
完成的
Hey there what fuses do i need to check?
完成的
添加一条评论
Hello could you fix the problem? I have the same problem but when i restore it on mac it says error 4014
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kenesco2001 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,627
