跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Is the front glass the same as the 6.?
Are the 6s and 6 front glass identical?
Im about the start glass only repairs and was wondering if the glass I've ordered is correct because they've Sent me glass that is identical in every way to my iPhone 6 glass.
Can anyone confirm for sure before I start laminating my 6s lcds to it? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
No. Different materials have to be used to allow 3D touch, and the exact dimensions may differ although I have not confirmed it.
这个答案有帮助吗?
得分 2
添加一条评论
The front replacement glass dimensions (width and length) for the iPhone 6 and the iPhone 6S are the same. The glass for the 6/6S will both fit into a iPhone 6 LOCA/OCA refurbishment mold.
What to watch out for:
The thickness of the aftermarket glass varies from vendor to vendor. The home button holes may be smaller not allowing proper fit of the home button. In the early days of the iPhone 6 glass coming out some where a little longer and would not fit into the mold. Some of the 6S glass my be a little longer from time to time depending if the manufacturer has got their tooling right.
The force touch is controlled by a sensor behind the back light. The glass has nothing to do with the force touch function. Though I imagine a thicker glass will have a slightly different feel(the type LOCA/OCA does make a difference on force touch).
My solution:
Dry fit your aftermarket screens into the mold after you receive them from your vendor. You can do this with the plastic covering on. Because you need that plastic covering on to keep the glass super clean before laying that glass down, especially the inside facing the LCD. Have a stock OEM home button to check the home button holes (just stick it in) or buy a dial caliper and measure. Why? Because let's say everything goes right and you are getting ready to put the screen on a phone and the home button doesn't fit, all that time and effort is wasted. Been there!
That's all I can think of right now. Feel free to ask any question you might have.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Neil Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 165
