跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
Earpiece sound is fuzzy after screen replacement.
I recently replaced the screen in my iPhone 5s. The repair went smoothly, thanks to iFixit's excellent guide. However, now the sound in the earpiece is very fuzzy. The speaker function works fine, just the earpiece. Any ideas as to what I might have done to cause this upon reassembly, and any thoughts on a fix. Might have I damaged the earpiece speaker and need to replace it?
Thanks in advance.
Ed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Ed,
It is possible that the ear speaker was damaged. It could also be misaligned with the contacts on the proximity flex. This has happened to me a handful of times and sometimes replacing the ear speaker fixes it. Assuming that it has no water damage.
Try these first:
-Take screen off and look at the top where the contacts meet the gold springs of the ear speaker. Sometimes if your eyes are good enough you can see if they are making good connection and have no corrosion present.
-You can try to loosen the screws of the metal ear speaker plate just a little bit and try the ear speaker (this happened all the time on the iPhone 5) without actually putting the screen back in the housing. Of course be very careful not to over extend the screen flexes.
-If none of that works source a new ear speaker and install.
-If that doesn't work then it could be a prox flex-but i feel it is one of the above answers.
这个答案有帮助吗?
得分 0
添加一条评论
I just stuffed a ball of blue-tack into the hole and it stopped. ;d
There's your botched repair if you'd like.
Make sure it goes inside of the hole, not covering it so sound travels through.. the ball of blue-tack will nullify the excess vibration on the speaker making the voice sound clearer.
Just don't use too much. ;d
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 458
