跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
black shadow on lcd screen
So i replaced my LCD screen on my iphone 5 and as you can see in the picture there is 4 sports spaced out on the top of my screen. It is very visible against a white back ground. I was think there is pressure on the lcd from the back plate so I loosened the screws. Is there any way to get rid of this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
That's not due to pressure. I think it's a bad quality screen and probabaly happens when the backlight behind the screen has gaps at the top where the light escapes.
完成的
添加一条评论
3个答案
已选择的解决方案
I agree with what Ben said. It appears your screen is faulty and not of high quality. Try an iFixit screen instead! Problem should be solved.
这个答案有帮助吗?
得分 1
添加一条评论
iPhone 5 Screen
Third party parts will usually yield third party problems
iPhone 5 Screen图片
产品
iPhone 5 Screen
$34.99
这个答案有帮助吗?
得分 1
添加一条评论
I had installed an OEM screen on my 5s, replaced the buzzer and put a new battery in. Had the same thing - "faint squares on the top of the screen" especially visible in passcode and locked screens.
The rest of the LCD looked great.
Took the screen off again. Made sure everything is connected properly.
Put the screen back on - same story. Had a look for possible clues and noticed that the body is all "wavy" due to tension somewhere.
Took the screen off again. Removed the shield plate all together above the clips. Made sure that everything is clipped in 110% as the board was mushy and had signs of dampness or water damage. Loosened the screen assembly screws.
Popped the assembly back in.
The shadowy squares at the top have disappeared.
Everything works well
Finally
So inn my case it wasn't the cheap Backlight / LCD layers (although i did drop it on the tile floor from a decent height) but RATHER the dodgy logic board connectors and the chassis flaws
p.s. Long story short - do only those 5s's only if they have NOT been opened before.
Otherwise think twice who tried to repair it and what was the history of that handset
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lucasallen2 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 3,477
