跳转到主内容
Static on internal sound system
Update on static problem. Appreciate the suggestion that it is a keyboard problem, or the start of HD failure. Replaced HD. No positive effect. Tried suspending keyboard in air (incorrectly installed or pinched wire). No positive effect. Static continues. Tried CD. optical works, but dialogue window says that Itunes is corrupted. Asks for reinstall. Internet connect to streaming no go. Programs without sound, no static. Running osx install disk with music and narrative-static. And the popping noise increases progressively. Reminds me of old vacuum tubes, getting worse as machine warms up. Any suggestions
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Whoever said it could possibly be a HD problem was way off. Have you tried a clean install of software? if not, I would start there. That failing I would open her up and check the speaker connections and the speaker cones. Has the machine suffered water damage or a fall? If not, try moving the machine to another location or plugging into a different receptacle and see what happens. Does this noise replicate on headphones as well, or just internal speakers?
这个答案有帮助吗?
得分 1
1条评论:
完成的
添加一条评论
How can I fix the static sound
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roger Bouilly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 818
