跳转到主内容
HP Photosmart printer introduced in 2010. This printer is considered ePrint capable. Has a card reader that supports Memory Stick Pro Duo, Memory Stick Pro-HG Duo, MultiMediaCard (MMC), MMC Plus, Secure MultiMedia Card, Secure Digital (SD), SDHC. An adapter is required for MMC Mobile, Secure Digital Mini, and MicroSD cards. This printer uses a 4 color semi permanent printhead.
Why does nothing appear on the paper when I print?
The printer has new ink cartridges, everything moves as it should but when I ask it to print, the paper comes out blank.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Hi, Where are you trying to print from, a PC or the printer control panel? If from a PC have you tried a copy or scan function using the printer control panel to see if it prints correctly? What have you tried to do to fix the problem?
Have you inserted the new cartridge(s) properly? Here is a link which shows you how to do this, so that you can verify that you have done it correctly. https://www.youtube.com/watch?v=gbZkq01F...
完成的
添加一条评论
1个答案
已选择的解决方案
You may have either a clogged print-head, or your cartridges may be exhausted.
这个答案有帮助吗?
得分 0
1条评论:
to take the printer apart follow this link
https://www.youtube.com/watch?v=1jkW1x9K...
完成的
添加一条评论
添加你的答案
frannie6539 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 724
