跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 个问题 查看全部
Ruling out a faulty battery for strange issues
I had recently picked up a second hand 3ds a couple of days ago, which was all in working shape (save for a faulty SD card slot). However I had noticed that while it has no problem turning on, the system will make a 'pop' sound and completely turn off when the power button is pressed (while the system is on), instead of going to the "In Sleep Mode You Can..." screen. Further experimentation showed that while the battery would charge, turning the system on while plugged in would cause the boot to abruptly stop (with no sound made), and the charge indicator to suddenly turn off.
I figured it would be worth trying to swap the battery, as the system went from having two bars to flashing red in about 10-15 minutes. I haven't had any of these issues with the new battery, but I'm still questioning whether or not it was the cause of the issues. I don't like tossing out components if I have doubt that they're broken, but I don't want to keep a potentially defective battery in my possession.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
By replacing the battery, you have proven that that the problems you were experiencing were being caused by the original battery.
All batteries have a life span, rechargeable types included. Failing batteries can cause all sorts of issues with electronics.
Your best course of action now is to responsibly dispose of the battery in an environmentally approved way.
这个答案有帮助吗?
得分 2
1条评论:
That's true. I guess I wanted to be sure that the issue was with the battery, instead of it coming around again well after the replacement, and leading to something else. Always want to be sure. Thanks!
完成的
添加一条评论
添加你的答案
Jill 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 7
总计 278
