跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
138 个问题 查看全部
no water comes out from the brewer head
For my machine, it even stopped making sound, of cause no water comes out from the brewer head. What could this mean? a broken pump?
Cheers,
Jin
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Mine has this issue and the pump labors to work. No water comes out.
完成的
添加一条评论
3个答案
已选择的解决方案
If the machine has power (heats, lights come on) but the pump doesn't make a sound when either the coffee button is pressed or the steam knob is turned, then yes it's possible the pump is completely dead. This is very rare though so I would make sure to check all the wiring and ensure the pump is getting power.
这个答案有帮助吗?
得分 1
添加一条评论
Pump does make sound, but nothing comes out. Steam wand works fine.
这个答案有帮助吗?
得分 0
添加一条评论
Thermal fuse which on the white wire may be blowed, use ohm meter to check,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wang27 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 693
