跳转到主内容
Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
66 个问题 查看全部
Touchscreen was hyperextended. Can this be repaired or replaced?
So my 70d was inadvertently knocked over yesterday at a wedding rehearsal. The flip out touch screen was open and, as it fell, it hit the grass first. The screen still works and functions, but now it has been hyperextended such that it won't return to the home position when swiveled around and relocated against the camera body. I will probably pursue having it professionally repaired but I wanted to at least ask 2 questions:
1. Has anyone ever had this happen and then possibly repaired it themselves?
2. Whom do you recommend for repairs like this?
Thank you for your time.
~Chris
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Hello Chris,
There's a video on YouTube (if you haven't already seen it) that gives you instructions for a teardown, with the specific purpose of replacing the Canon 70D LCD Assembly. {I got mine for about $120 shipped on aliexpress}
Here's the link:
https://youtu.be/N4jD6_6R_r8
You will need an electrical socket set (or eyeglass socket set) because the screws are "super duper"<-- technical term-->small. You don't have to worry about losing them because you already have them in the new assembly piece.
Takes roughly an hour. Well worth it though!
Let us know your success!
E Johnson
这个答案有帮助吗?
得分 1
2条评论:
Good vid, but the guy must be a pro working that fast.
完成的
Actually, if you are motivated to do it, take your time, and keep track of the pieces to go in reverse, it's super easy. Obviously though, if you're scared to mess with your camera's internal parts, you should get someone to do it who does stuff like this.
完成的
添加一条评论
添加你的答案
Chris Thompson 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 18
总计 1,005
