跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1698 个问题 查看全部
Ps4 won't turn on. No beep or blue light
My friends Ps4 disk drive was jamming so instead of sending it back and getting it repaired with the warranty he opened it up and tried fixing it him self. The pins in the Disk drive were not aligned so he aligned them. He then put everything back together but when he tried turning it on nothing happened. It doesn't turn on there was no beep and no light. My friend ended up just buying a new ps4 and gave me the broken one to see if I can fix it. My first thought was that it was the power brick so I swapped it out with a new one but it's still not turning on. Is there anything that I can try? I've checked all the wires and they are all connected, I honestly do not know what to do next. Before he took the disk drive out it was working fine how it could it stop working? Please any help would beappreciated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The top cover is probably just not in place correctly. There is a small metal piece that needs to be in the proper place to touch the copper pad on the motherboard that turns the PS4 on. To check this just remove the top cover and touch the copper pad with your finger (and with the PS4 plugged in). If it powers on then you know you've found the problem.
Good luck!
这个答案有帮助吗?
得分 3
3条评论:
I'll be sure to try this out too. Thanks kyou
完成的
I just tried that and it didn't work. Is there anyway to check if a wire is bad?
完成的
I'm assuming you were sure you were touching the right place. What wire?
完成的
添加一条评论
I would assume the same if it showed no power being plugged in, but if I'm not mistaken there probably is a ground that is not in place correctly and is not allowing it to power on, I would start with a good video on a tear down and as ur following it take inventory of anything that might be missing or out of place
https://m.youtube.com/watch?v=1JAhv9Ed-N...
I watched some of this seems to be enough to locate anything missing, I can't find the video I originally watched to learn how to taredown one but let me know what u find
这个答案有帮助吗?
得分 1
1条评论:
I'll give this a try as soon as I get a chance. I'll keep you updated
完成的
添加一条评论
添加你的答案
Anthony Santiago 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 3,855
