跳转到主内容
Repair information for the Huawei Ascend G7 smartphone. Released in 2014. Model numbers: G7-L01, G7-L03, G7-L11, G7-UL20.
47 个问题 查看全部
Ascend G7 wont turn on (battery problem?)
I am fixing a friends G7 and basically it just wont turn on. Pressing and holding the power button provides no response from the phone what so ever. The screen stays black and there is no vibration or anything. The phone doesnt seem to charge properly also. When i plug it in a solid red light appears (i think it informs that the phone is charging) but after about 5 minutes of charging it goes off. I have taken the back of the phone and measured the battery voltage with a voltmeter. The battery at first read 2.50V. After trying to charge the phone multiple times yesterday it has raised up to about 2.8V but the phone still wouldnt turn on. So i plugged it back into the mains and left it charging for about an hour. I came back measured the battery voltage and it was 2.6V. This morning i left it in the mains for a good 9 hours and when i came back to check the battery voltage it is only 2.67V. I think that the battery might be a problem here but i want to get any second opinions before i buy a battery. Also is there any way of turning the phone on with the battery unplugged? Thanks for any responses
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Hi were you able to fix your problem with your phone, i have the same issue and cant find any solution?
完成的
添加一条评论
2个答案
Pulsing red light and black screen are keeping it from turning on
这个答案有帮助吗?
得分 0
添加一条评论
I’ve got the identical issue. I’ve absoultely no idea about the problem. Is there any comment about this issue?
这个答案有帮助吗?
得分 0
1条评论:
Salaams were you able to fix your problem with your phone, i have the same issue and cant find any solution?
完成的
添加一条评论
添加你的答案
kris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 2,084
