跳转到主内容
加入维修社区 - 创建账户
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
GPS Problems - Not accurate
Hi! I'm new here, so I am not sure how this works. My Galaxy S6 Edge got wet 3 weeks ago. It wasn't anything big and after 1-2 hours in rice it works fine. The only thing (and I am not sure if it got something to do with this) is that the GPS is not working correctly. When I try to use Maps App, it is not accurate. I've done everything I read, even did a factory reset, but the problems continues. I downloaded another navigation app but I received a message that the GPS is not accurate. I wonder if there is any other thing I could do or if this is something that can be fix if I take the phone to a repair store.
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Ensure the GPS accuracy is set to high in settings.
这个答案有帮助吗?
得分 1
添加一条评论
Use the Power Button to fix the GPS / W-LAN Problem.
Press and hold the Powerbutton more than 10 seconds.
After the reboot works your smartphone without the GPS Problem.
or try it with the Google Play Store App " GPS Status -Test & Fix
You have to delete the A GPS Data first on the left side and then push the right button ( app is in german)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sandra Velazquez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 969
