跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
Screen won't come on.
I was playing a game then suddenly my iPad turned off. I thought it needed to be charged I recharged it and it will not come on. It is only 8 months old.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
What model iPad do you still have?? If it still under warranty take it back to Apple. Otherwise try these hints. 1. Make sure you are using original apple charger, try other charger. 2. Make sure you are using the larger charger brick for the iPads, they put more power to the device. 3. Plug the iPad with charger, hold down the home button and power button and hold both until the apple icons come on. If you see the apple icon, your back in business!!! If no apple icon then head to apple to swap out!!
这个答案有帮助吗?
得分 0
添加一条评论
Hey Wendy Sanders,
Maybe it still has warranty from where you bought it, first check that out so they can help you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wendy Sanders 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 113
