跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
426 个问题 查看全部
Why is my horn going off when I recon ve my battery?
I have an 2002 Honda Accord and recently it was dead for a few months til I charged the battery once I put the battery back I connected the positive and then right when I connected the negative the horn started going off does it have an alarm? How can I stop it from doing that? Or what's up? And also my radio says "code" I have the code but idk how to put the number "0" help! And can I disconnect the alarm if there is one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
My Durango will do this if you unlock the door using the actual key instead of the keyless. While the horn is going off get in and start the car, that should get it to recognize any chip in the key and turn the alarm back off. For the radio, the code should be a 5 digit number 1-6 if I remember correctly, only the serial number for the radio should have 0's in it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dominic Gallegod 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 45
总计 12,323
