跳转到主内容
加入维修社区 - 创建账户
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
Right antenna damaged during screen replacement
I damaged the right antenna (right side of the home button) during screen replacement. Is this part available? How will the ipad function with it damaged?
Update (05/01/2016)
Its the wifi version. I did find the part on Amazon, expect to get it in a day or two and will install and test out my repair.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I have this problem as well, but mine is the LTE model. Do I still need to get the GPS Antenna Flex? Or is the right antenna a different part on the LTE model?
完成的
添加一条评论
2个答案
最有帮助的答案
Is you model the LTE or WiFi?
What is the extent of the damage? Have you completely severed the cable? Post pictures if you can.
As to whither or not it will still function, it might, the iPad has two combi WiFi/Bluetooth antenna, but it might not have the range it had.
这个答案有帮助吗?
得分 2
添加一条评论
Yes the antenna is replaceable.
You have damaged the "GPS Antenna Flex".
这个答案有帮助吗?
得分 0
1条评论:
What is the part number for this?
完成的
添加一条评论
添加你的答案
Andrew Curtis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 523
