跳转到主内容
Released May 2012, identified by model number J2011-03-US.
45 个问题 查看全部
Bluetooth working but very low sound level - jack sound level works
How does the jack socket connect to the blue tooth sound control blue tooth connectivity appears to be ok - I have just repaired broken jack by re-soldering connections after the unit had been dropped with jack and wire connected breaking the solder joints on the board.
The sound level and control is back to normal when using the jack plug, but the blue tooth sound volume is just about audible and does not appear to respond to volume control.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Not certain of the circuitry of your music player.
Try the following:
Connect music via Bluetooth, (output low as it is).
Can you hear the music in both speakers or only one? If only one then which one left or right?
Next, leaving the Bluetooth music playing, plug a jack into the socket, it doesn't have to be connected to anything at the other end. If the music stops it proves that the socket disconnects the Bluetooth music to the amplifier.
Depending on whether you did hear the Bluetooth music in only one speaker and which one will influence what you may look for next.
With a lot of sockets there are changeover contacts connected to both the 'tip' and 'ring' connecting springs of the socket. This means that when a jack is inserted these contacts break the existing input circuit to the amplifier section (in your case the Bluetooth music) and connect the jack input to the amplifier circuit.
The convention is that the left speaker is connected to the 'tip' connection and the right speaker is connected to the 'ring' connection. The 'tip' is the end of the jack furthest away from the cord and the 'ring' is the next one after the insulating spacer. The last connection is known as the 'sleeve' which is closest to the cable and is used for the 'common' for both left and right speakers.
So if you are not hearing music in the left speaker and your socket does have the changeover contact configuration you need to check the connections to both these contacts associated with the tip connector. The same goes for if you have no music in the right speaker you need to check the ring changeover contacts connections.
If the music is in both speakers and connecting the jack does not stop the music you may have the other type of socket where there is only a single contact used which either makes or breaks when the jack is inserted and this is used to "tell" the amplifier to switch the input source from the Bluetooth to the socket. It may be that you will have to trace back the circuit from the amplifier input, (following where the tip and ring connections from the socket go will probably lead you to the input) then see if there are other paths that hopefully will lead you to the Bluetooth output and that you may spot the problem. Perhaps a broken connection or a dry joint.
Sorry I cannot be more exact and that hopefully it is of some help.
这个答案有帮助吗?
得分 3
2条评论:
opened up speaker and placed two over laying double sided thick double sided tabs inbetween the casing and headphone port. In order to squash loose soldering together permenantly.
完成的
Hi Frank, I am having the same issue, very low sound on both speakers after dropping the speaker with a jack cable plugged in. When I opened it up I noticed the jack connector part wasn't quite in place so I removed it completely, didn't solve the issue.
Could you please explain "two over laying thick double sided tabs"?
完成的
添加一条评论
添加你的答案
Mike Gibson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 4,029
