跳转到主内容
Released 2015, identified by model number Z812.
55 个问题 查看全部
Why isnt my phone taking a charge when it is plugged in?
My phone recently doesn't want to take a charge with any cord but i would have to move the cord around for it take a charge.
Can anybody help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Charger stem won't take a charge
这个答案有帮助吗?
得分 1
1条评论:
the wires where they meet between the charger end and the port on the phone arent linining up because over time they get bent and break ,if its in the port on the phone you need to get a new phone after a while it will break and unless you can swap out and solder a usb port you should start backing up your phne filles ,if its the cord with bent terminal wires replacing thats no problem
完成的
添加一条评论
I learned with my maven that of u switch to a lower voltage like a old house charger instead of USB charger works great mine would die and the old chargers was the only way to get it back on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nascarbigfan12 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 333
