跳转到主内容
Polaroid Sun 600 LMS instant camera. Released 1983.
My Polaroid Sun 600 LMS camera will not charge?
I put the brand-spankin'-new film pack into it, and the camera seemed happy (it spit out the dark slide like it was supposed to, and when I held down the trigger half-way to charge the camera, the red light came on to indicate that it was working). However, after waiting the allotted time, the red light never changed to green, and the camera has not flashed once upon fully pulling the trigger. It hasn't even spit out a blank image.
According to my research, I should be able to hear it charging, but I hear nothing despite clearly seeing the red light indicator. I've attempted to take photos in various lighting situations, all indoors, sometimes with natural light and sometimes with electric, all to no avail. It isn't an issue of temperature. It isn't an issue of distance.
Clearly, there is power, and clearly my camera receives this power to a certain extent, but it isn't flashing, and it isn't actually capturing any images. It's like it's trying to send the power to it, but halfway there it hits a wall.
Can anyone tell me what I should do? If it's a bust, that's fine, but I got my camera for a very good deal, so if I could simply replace a part rather than replacing it entirely, that would make my life. No one else seems to have had this problem that I can tell from mere Internet searching. I'm rather attached to the little guy in spite of the fact that he doesn't seem to have actually ever taken a photo.
I have wanted to own a polaroid since I was a little girl, and everything was going so well (until the fire nation attacked). Any advice would be welcome!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
I have the same problem. There is a permanent beeping and the red light never goes off. I've tried it with new film packs. What should I do?
完成的
Try Deoxit D5 contact cleaner, it worked for me.
完成的
Where do you put the cord to charge this at??? Please answer
完成的
Hi @ Abby Hettmannsperger,
There is no battery in the camera to charge.
The battery is in the film pack that you load into the camera.
You cannot charge this with a cord.
See the first answer below.
完成的
添加一条评论
4个答案
已选择的解决方案
Did you use one of those old expired Polaroid 600 film pack or a new Impossible Project film pack ? There is a good chance something wrong with the film pack than camera. My guess is half dead battery specailly if you used an old Polaroid pack. There is a little chance you have a dead battery problem with Impossible Project packs but you can never be sure. I guess only option you have is trying another pack.
这个答案有帮助吗?
得分 2
添加一条评论
Try some of this stuff, spraying some contact cleaner inside the shutter release button and inside the cracks of the flash connection to the camera and on the copper plates where the film pack goes. I tried this when I had the same problem and it worked within 10min. I used "Deoxit D5". You can get it on Amazon. Good Luck!!
这个答案有帮助吗?
得分 1
添加一条评论
I have found a partial way around this if you don’t need the flash. I didn’t realize there are two buttons. There is the main one with the red on the front but the other one is just behind it and hangs down. This is for shooting thru windows. I have gotten it to charge long enough to get film out of the camera. I noted that this pack expired 2018, I bought it 2019. So odds are the new batteries don’t last as long as the old ones even though usually when I get thru a back , I can take that battery out and still have 5-6 volts left on the battery (good enough to ruin an LED to test. (1.5/3 volts max 6 volts no! I have managed to charge some phones cutting the bad USB micro cords and reusing those. pretty much any crappy new micro only usb cord would work. mini usb and usb c I haven’t had issues with those. Thats just for recycling the battery power. WD-40 makes a contact cleaner but where the heck do I shoot it in for flash contacts , I know where the power ones are although usually you need something to rub it out and rubbing the sparky battery isn’t a good idea.
这个答案有帮助吗?
得分 0
添加一条评论
So mine was having the same issue, I sprayed some W-40 on the inside where the two metals are in the back. Not sure if it needed it. But the only way it took the picture with flash was when I held the photo button down for about 3-4 seconds and it took the photo. The red light never turned green, it was showing red the whole time until it takes the picture. The photos all came out with a slightly purple hue though.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lauren 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 60
总计 8,586
