跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
My iPhone will only come on when charging
My iphone 3gs will not shut-off no mater what i do,i have tried holding the power and off button at the same time nothing.also when charging the screen is dark were you could barely see the apps,but will not change apps when i hit the home button,nothing happens.any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Firstly try restoring in itunes, then see if you are still having the same issues. If it's still behaving strangely after that i'd crack it open and inspect for liquid damage as the faint screen is often a sign of this.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lloyd 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 870
