跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
Dead after screen replacement
Hi all-
My iPhone 6 Plus was working fine, but had a cracked screen. After replacing the screen using the iFixit kit, the phone is completely dead. It will not power on, reset, or respond to iTunes when plugged into my Macbook. It does get warm when connected to the charger, but that's it. Any suggestions?
-Garland
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
I think a cable is not connected, open the phone and look if everything is connected.
这个答案有帮助吗?
得分 0
添加一条评论
Yes check all your connectors to make sure they are connected correct. Unhook the battery from the motherboard and then reconnect after 10 mins, power up and see what happens. Do you know what % your battery was at prior to doing the screen replacement?
这个答案有帮助吗?
得分 0
添加一条评论
Plug it into your Macbook, and do this: 如何强制重启iPhone 6 Plus
If it doesn't show up then it's probably the logic board. I would open up the phone again if the method above doesn't work, and check to see if any components missing off the logic board by the screen connectors.
If it does however show up, then I would check to see if normal things are working such as the silent switch or Siri. If they don't (I had this happen to me on my 4s) then it might be the logic board (in my case it was).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
garlandstephens 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 216
