跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
问题已关闭
Install of Win10 failed with BootCamp 6
I have a model 1286 MacBookPro 9,1 and the UPGRADE to Windows 10 worked on it from the previous installed Windows 8.1 PRO ...
But installing on a new SDD failed with Boot Camp 6 later, any idea what could be the problem ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Who's SSD is in the system?
完成的
MINE ! ;P
( Samsung SSD 850 EVO with 1TB )
完成的
添加一条评论
1个答案
Using an external Mac OS-X bootable drive open Disk Utility and reformat the disk to GUID patition map and create a journaled file system partition for the Mac OS. Once done install a fresh copy of OS-X onto the SSD. At this point I would make sure the systems firmware is up to date. Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers. Make sure you are at the level listed or newer. I would also make sure the OS updates are also applied at this point.
Here is the Apple page which goes over the process of setting up Windows with BootCamp: Boot Camp Support
And here is a link to the Windows drivers you'll need: Accessing the Windows drivers via Boot Camp Assistant app.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 621
