跳转到主内容
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
119 个问题 查看全部
How do I replace the charging assembly on my Note 10.1?
The current port will no longer establish a valid connection even when I use a new cable. I've purchased a New Charging Assembly from IFIXIT and I need directions to change it out. It is a Galaxy Note 10.1 (2014, WiFi)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Here are two videos which may be of some help.
This one (which is actually to show how to replace the battery) is good because it shows how to open the tablet and also how to release the charge port flex cable from the systemboard. It doesn't show the removal of the charge port however.
https://www.youtube.com/watch?v=y7PP4tCJ...
This one, of lesser quality, actually shows the removal and replacement of the charging port.
https://www.youtube.com/watch?v=uVNCdPoR...
If you watch both first, no doubt you will have a good idea of what you need to do.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sueraebell 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 423
