跳转到主内容
The HP Officejet Pro 8600 Plus is identifiable by its model number: N911g. Released in 2011, the printer can be identified by its brown finish and touchscreen control panel.
How do I remove paper stuck to the ADF?
Paper is wrapped around the ADF. I can't access it by opening the ADF cover. How do I access the unit do I can remove the paper?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Hello,
I'll help you as best I can. What do you mean you cannot remove it? Because the paper is ripping when you try to pull the sheet out?
If so, remove what you can from the rear of the printer. This may not get all of the paper, but then open the front where you replace ink and that too will give you access to the ADF. You should, key word should, be able to remove the rest of the paper from the front.
Hope this helps & have a great !
这个答案有帮助吗?
得分 0
添加一条评论
my printer is not pick-up the paper, It say no paper but we have papers
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pnewbold 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 2,328
