跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Replace screen of iPhone SE with a screen for iPhone 5s?
Hi,
I see on iFixit that the screen is the same between iPhone 5S and iPhone SE.
I am looking to replace my screen but I find no seller for "iPhone SE screen".
So I bought a screen for iPhone 5S on a merchant site. Will it be compatible? Or not necessarily ?
Thanks in advance !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
This guide suggests that the iPhone 5S part is not compatible with the SE. So now I am confused: https://eustore.ifixit.com/en/Parts/iPho...
完成的
添加一条评论
6个答案
已选择的解决方案
Completely interchangeable. However don't forget to transfer the original home button over.
这个答案有帮助吗?
得分 3
1条评论:
Have you yourself successfully changed the screens or are you saying this based on what you have read/seen online?
完成的
添加一条评论
I have tried three 5S screens from different suppliers on the SE and they all had display issues, Lines of pixelated. Tested all screens on a 5S and they were perfect......
这个答案有帮助吗?
得分 3
2条评论:
same version of iOS?
完成的
I have also observed this .... Tried all 6x 5S aftermarket screens I had available and got lines , glitches etc even though the display and touch functioned without an issue.
These same screens in a 5S work perfectly
My supplier has just sold me what they referred to as a "refurbished original" a screen so I am going to try that! Will update here when I have fitted it.
完成的
添加一条评论
You pretty much have to use oem parts for the 5s parts to be interchangeable.
Otherwise the refurbished ones out there tend to make the screen shaky and give off all sorts of graphical glitches.
这个答案有帮助吗?
得分 3
1条评论:
Thankyou this has answered my question i was getting all sorts of issues
完成的
添加一条评论
I have read that they have the same display, you can buy a iPhone 5S display and put this on iPhone SE.
这个答案有帮助吗?
得分 1
添加一条评论
they can share the same LCD screen except the home button, i found this iphone se lcd screen http://www.etradesupply.com/apple-iphone...
这个答案有帮助吗?
得分 0
添加一条评论
I have changed displays on iphone SE. Copy screens had all kinds of errors, interlaced picture, colors are bleeding out from app icons and moving around alittle.
Original 5S screen worked fine, but now 2 days afterwards a customer contacted me that the lighting is off, and sometimes the touch stops working. So she will be back this monday.
Odd thing tough, when I removed the broken screen, there were no Apple logo on the flex cabels connecting the lcd&touch to the mainboard in the phone. instead there were 4 dots in a squared form.
looked like a copy screen basicly.
这个答案有帮助吗?
得分 0
1条评论:
I also tried a few different 5s screens and while the touch worked fine they all had severe problems with the display.
完成的
添加一条评论
添加你的答案
Kalorte 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 21
总计 4,429
