跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
What is my iPhone dying so quickly
When using my iPhone I usually charge my phone to 100%. However my phone tends to die around 70% to 90%. Then after a few minuets I turn it on to find it at around 70% to 90%. When it's not connected to a charger it would turn off right after the device has been powered on. i drained the battery but it would again power off if no charger is connected to the phone. I was wondering if I should buy another battery for the iPhone 6?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Hi Eric
What may be beneficial for you is to contact a Apple Support Rep and get them to run diagnostics for you.
If your battery fails, then you can consider replacing the battery.
It is a common misconception that it is "good" to discharge your iPhone battery , lithium-ion batteries found in iPhones should not be discharged to the point of zero, it will shorten the battery life of your iPhone.
Regards
Brayden
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric Del 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 123
