跳转到主内容
A 1.9 GHz DECT 6.0 multiple channel handset capable cordless phone, VTech CS6719-2.
9 个问题 查看全部
Power to base dies after 3-4 seconds after power is applied
Phone says "No Power to Base".. I unplug power connector from the base wait a second and replug in..The red LED turns on, within 2 seconds gets a little brighter for 1 second then totally dead.. I have checked power supply (5v) with a 5v source and same result..Cable isn't the problem because it's not intermittent. Same results consistently. the excess light before it goes dead , I'm thinking is a capacitor discharge, possibly through a hot shorted transistor.. Any thoughts out there?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Is the battery icon in the phone showing that the battery is fully charged?
The charging light will extinguish when the battery is fully charged.
Does the phone work at the charging location?
The No Pwr at Base message can also indicate that the phone is out of range.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jay Trix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 1,108
